Using Wideband O2 in narrowband front O2 bung for testing
Old 02-18-2005, 03:09 PM
GTO_Scott's Avatar
Default Using Wideband O2 in narrowband front O2 bung for testing
I know I'll get errors but can I installing my wideband O2 in the narrowband bung just for some dyno runs? Can I use HP Tuners to disable any learning while the drivers 02 front sensor is removed and not reporting?
Hope this is a simple question others have asked.
Old 02-18-2005, 03:14 PM
horist's Avatar
https://ls1tech.com/forums/pcm-diagnostics-tuning/269427-remove-o2-wideband-reading-dyno.html
Old 02-18-2005, 04:21 PM
GTO_Scott's Avatar
Thank you!
