TCI th400 and speedometer sensor
I have a 95 camaro going from an m6 to a th400. Some guy at tci told me that i couldn't make my speedometer work after I did the swap. any idea? part numbers, etc?
Use the sensor & reluctor ring that came on SS454 pickups that came with TH400's.
PN 8655291-speed sensor & PN 8655315-reluctor ring.Then with edit go to speedometer>speedometer input>pulses per mile and adjust the pulses per mile to match your rear gear/tire to get the speedo correct.Look at the ABS wheel speed sensors to get your correct speed going up the road.
My setup is for a 70's car conversion, can I adapt a wheel sensor?
I do not need it for a digital dash reading as I still retain my speedo cable, I just need it so the PCM see's a signal and the car doesnt stall.
