How to change oil pump w/out dropping pan completey>?
I think I know the answer BUT...
Have intake, heads, headers, front cover, radiator, etc. off car...decided to get new oil pump and timing chain as well....
I am looking at the pump pick up tube, and can't see how I can remove the pick up tube from the pump withouth lowering the pan a lot...any suggestions? Hate to drop the front suspnsion....
SDB
SDB
Just loosen the oil pan bolts so the oil pan lays on the k member. And, use a 10mm wrench to get oil tube bolt off of the oil pump.Then the hard part is next putting that bolt back in the oil pump. I used the 10mm wrench to start the bolt back in the oil pump. It is hard as **** to get it back in there but you can get it.
