tune for pump and injectors?
well its just as the title says. would i need to get a tune for my car if i get 42# injectors and a walbro 255lph pump for my car. right now its completly stock but should i wait till i get my turbo system or should i throw it on now? if it helps im going with the sts system for my z. well any and all information or suggestion would be greatly appreciated
Coal Mining Director
You will need a tune for the 42lb injectors. Then you will need another tune after you install the turbo. I wouldn't waste the $$$ on 2 tunes because you will not gain any hp with the stock motor. Wait and install the package and do one tune.
I had the same question when i was doing my Turbo. What i did was install the fuel pump. Then when i did the turbo put in the biger injectors and had it tuned. Had the fuel pump in for like 2 weeks before the turbo
