GMPP LS6 CNC heads, TR224 on 114 LSA??
Anyone using this combination? I am interested in rwhp/rwtq numbers. I know the driveability will be fine with a good tune and that more hp/tq can be made with different head and cam combinations......Just interested in information about this combination.
Thanks
Thanks
thats a nice lookin vette bro! have you checked out the dyno section yet? you might have more luck there. i know those heads do put down some decent numbers, tho not quite as nice as TEA's Stg2 LS6 heads
Well, looked in the dyno section, but couldn't find the information I am looking for. Hopefully, someone on the forum will have some info.
Thanks
Thanks
I just installed this cam with ls1 ported heads and my HP is in the sig. Its not tuned yet and kr pulled some timing so I should beable to get anothe 10-15 hp.
The big intake ports on those LS6 heads are begging for a large cam, not a 224 grind or the like. The combo will work but a smaller intake port will work alot better with a TR224 grind. The AFR 205's, Rapid's Stage II's, TEA 1.5's are what I would be looking at if adding heads to a TR224 setup. HTH
Thanks
dunno if it helps.. but my auto made 399 with a 224 114 cam cam on tea 1.5 heads
I would think you should be over 400 with full bolt ons with a M6 and those heads... maybe 420ish-430ish?
ditto the 380ish roughly.... good for a M6.. either way your car should scream from a roll
Interesting, so an LGM G5X1 or X2 would be more effective for th LS6 CNC heads?
Thanks
Thanks
Originally Posted by Cal
Yes, you need to be looking at larger cams. A least something in the 230 degree duration range. TSP Magic stick, or even the cam I have (see sig.) Both are pretty streetable with a good tune and will make your vette go like hell.
