Drag Racing Tech
Can I use the BMR Extreme Torque arm with SLP subframe connectors?
Old 02-19-2005, 12:18 PM
speedo's Avatar
Default Can I use the BMR Extreme Torque arm with SLP subframe connectors?
Looking a buying an extreme BMR torque arm, will this work with my slp subframes? On thunders website states; Will not work with "diamond" style subframe connectors. But has anyone tried it...?
What else can I go with for a stronger torque arm that doesn't weigh a ton?
Thanks....
Old 02-19-2005, 11:17 PM
White98Z's Avatar
i have been looking at that and dont see whay you couldnt cut the slp subframe connecters where it comes in to connect witht he cross bar and weld it all together.
Old 02-20-2005, 12:13 PM
redline2k's Avatar
Could you not just cut the bmr cross bar to fit to the diamond part of the subframes?
Old 02-22-2005, 01:50 AM
speedo's Avatar
That is a good idea I will have to have my mechanic take a look at. I will have to ask if that Chromoly can be welded..
Old 02-22-2005, 08:25 PM
sikws6's Avatar
I believe the torque arm crossmember is DOM steel (mine was) it can be mig welded or tig welded to your subframes.....
Quick Reply: Can I use the BMR Extreme Torque arm with SLP subframe connectors?
