Come On Guys Help A Brother Out!!! 408 A4 Cam
Old 02-19-2005, 12:27 PM
lewi1032's Avatar
Default Come On Guys Help A Brother Out!!! 408 A4 Cam
Hey guys i need any input on what cam selection you would recommend...this is what i have:
1999 hard top z
A4
6.0L IRON BLOCK
408 STROKER
TEA STAGE III 6.0L HEADS
LS2 INTAKE W/ 90MM TB
KOOKS 1 7/8 LONGTUBES
KOOKS Y PIPE
MUFLEX 4" CATBACK
I just drive this on the weekend and would really like to get ALL i can with this cam selection but I dont want it to where it is undependable as well, currently i have a comp 238/240 112 605/609 but i was thinking this might be a little to mild....I am hoping to get into the 500-530 dyno numbers with matching torque....So anyone with a similar setup please let me know what you think!!!!
Old 02-19-2005, 02:07 PM
JZ'sTA's Avatar
If you have good compression and a good tuner you could defentially go bigger and still have a driveable setup.
Call TEA and see what he suggest since he know's his heads better then anyone else.
I wouldn't be scared of a 244/248 or maybe even a 248/252.
Start going much bigger and your tuner is gonna hate you.
Old 02-19-2005, 02:08 PM
JZ'sTA's Avatar
What kind of power numbers are you making now?
Old 02-19-2005, 06:58 PM
lewi1032's Avatar
Actually The Block Is At The Machine Shop Right Now And I Am Thinking I Want To Go Bigger... I Should Be Around 11.2.1 Compression With My Setup But I Just Want To Hit The 500's And Dont Know If That Cam Will Cut It
Old 02-20-2005, 02:55 PM
SILVERZZ28's Avatar
Ttt !
