Will 17x11's with 315's Rub???
Old 02-21-2005, 02:38 PM
RGV_Z28's Avatar
Default Will 17x11's with 315's Rub???
My car is lowered, and I've heard people say that 17x11's wioth a 315 tire will rub on a stock height car. Is this true??
Old 02-21-2005, 04:39 PM
BTLFEDSS's Avatar
I think with the BFH method and a adjustable panhard rod to center the rear you'll probably be okay.Some with 315's want to help RGV out
BTLFEDSS
Old 02-21-2005, 06:06 PM
ferariguy3's Avatar
also depends on how hard you drive into corners, if your racing into them, the car will have body roll, and it may rub a lil bit
Old 02-21-2005, 06:55 PM
Possible Scammer - Buyer Beware - Issues Unresolved
00ls1's Avatar
BFH and they fit fine
Old 02-21-2005, 07:05 PM
silver02Z's Avatar
My 02 Z has been lowered with 17x11 ZR1s 50mm offset in the rear...Believe it or not I did nothing and they fit w/o rubbing...Because my car is lowered it misses the bumpstops completely......Hope this helps..
Old 02-21-2005, 07:39 PM
cowboys z28's Avatar
do they stick out past the fender well any silver02Z??
Old 02-21-2005, 10:37 PM
Arachnotron's Avatar
Mine rubbed when I backed out of my driveway at an angle. A BFH took care of that.
Old 02-21-2005, 11:32 PM
RGV_Z28's Avatar
Whats the BFH method??
Old 02-22-2005, 12:49 AM
skewba98z28's Avatar
This will answer your question read the first post.
https://ls1tech.com/forums/wheels-tires/120716-wheels-tires-everything-you-should-need-know-here-must-read.html
Old 02-23-2005, 09:20 AM
silver02Z's Avatar
No sir...Not at all
Old 02-23-2005, 06:40 PM
Mr. Furious's Avatar
I'll let you know in about a week
