Gears & Axles - Axle question
View Full Version : Axle question
Judd
11-17-2001, 07:30 AM
I've got a 2000 Firebird without trac. control, will a axle that has trac. control swap into my car without any problems? I know it will bolt up, but will any of the electrical connections be different?
Nine Ball
11-17-2001, 10:08 AM
Yes, it will bolt up, but your ABS will no longer function. An axle with traction control has two sensing reluctors, one mounted just behind each wheel on the axle ends. On a non-TCS car, there is only one reluctor wheel, and it is mounted on the backside of the differential.
3-channel ABS vs 4-channel ABS
Tony <img src="graemlins/burnout.gif" border="0" alt="[Burnout]" />
Judd
11-18-2001, 04:53 PM
Is there a easy way of getting it to work, would like to keep my ABS. Also don't want the ABS light on all the time. <img src="images/icons/frown.gif" border="0">
[ November 18, 2001: Message edited by: Judd ]</p>
