will it snap or will it be just fine
i have a 01 blackbird only thing i have done is 315/35/17 on the rear i have very bad wheel hop in 1st gear.. and 2nd gear.. im getting some L.C.A. put on if i go with a nitto drag tire after i put the L.C.A. on but keep in mind the sticky tires will be a 315/35/17 size will the rear end be ok or snap!!!
You should be ok for a while. Start thinking bout the 12 bolt or 9 inch though. I am running a stock 10 bolt with 4.10's and is holding up with the et streets, but not for long...
Moderator
I think that you want relocation brackets if it's
lowered, better shocks if it's lowered with higher-
rate springs. And practice driving for maximum
acceleration within the adhesion limits rather
than wheelspin. You accelerate faster if you don't
spin, anyway. If you have a suspension-geometry-
induced hop problem, stickier tires may make things
worse instead of better; more violent. Be a smoooth
lovah until you can get the suspension sorted.
