Spacer?
Spacer?
I have a 98 formula and I plan on getting some replica Zo6 wheels. I really want them to fit perfect so I know I will have to run spacers. 18x9.5 front and 18x10.5 rear with a 295 out back is the plan. the wheels are 57 front and 58 rear offset. I want to run a 1/2 inch spacer which will make my offset right around 45 if i did my math right. Should I have any clearence problem with that offset? The car is lowered about 1.5 or so inches. Also with a half inch spacer will it be a good idea to get hubcentric spacers? I don't want it to be cheap. And its's cool if you run spacers on the front right?
so it would be better for maybe a 1/4" in the front? so with a 57 mm wheel and a 1/4" spacer would in look like it is sitting right for the front with a 9.5 and a 275 tire. Would you still say hubcentric with a 1/4"er? and with replacing the studs just get hardened ones or they need to be shorter or longer?
