Maf vs Direct Port
Maf vs Direct Port
which is safer? which one will do 200hp shot cheaper? Hell at the price that its cost me should i go with a turbo so i get some respect when i pull up to the meets.
Restricted User
Most will agree a DP is the safest way to spray larger shots, although there are quite a few running the Single Nozzle wet, MAF etc with 200. The single nozzle can only atomize so much effectively, so twin nozzle or Dual MAF would be better than a single. Theres also the debate of puddling in the intake, or more so, the scariness of it which pushes many to go to a DP. I personally like the DPs but will be running 200 on a Twin Nozzle setup for a little while. A DP can be set up for less than $2500 with stand alone fuel system so no way in hell does the $ justify going FI.
Charlie
Charlie
Shorty Director
Originally Posted by Nitro Dave's Nitrous Outlet
Actually.If you do not plan on going over a 200 I would do the single nozzle or maff kit.Directports are nice but alot off work and money.I have customers spraying 350 through single nozzle kits with no problem.
Dave
Dave
I prefer my NX MAF kit over my old NX DP setup for several reasons. One being that anytime I want to increase or decrease the shot I'm running, it only takes two jets instead of sixteen.
Dave
Dave
Dave
Dave
hehe, thats a lot!
and i thought my friend was livin on the edge. he has a 355lt1 and is spraying 300 from one solenoid into two nozzles. races it every friday at the track, no probs. even crazier is he still has stock injectors, and is running 9.89.
Originally Posted by Homeslice (tm)
Which nozzle are you using?
The nozzle is the SHO Nozzle.You are currect but if thats all you can use thats alll you can use. 200 or even 250 on the single nozzle is no biggie.
Dave
The single NOS#16000 solenoid will flow over 300hp pretty easily.
Your restriction is the nozzle.
