Tunned Port Injection?
Originally Posted by Kalr'sJr
Hello everyone. I wanted to know if my Tunned Port Injection off my 305 will fit on a 350 small block?
Yep. no problem at all. Just make sure the base of the intake mathes the heads.......ie center bolt or perimeter. Most aftermarket bases now have provisions for both.
Chris
pre '86 heads have the center bolts at an angle so depending on the year of your heads you may have to notch the middle bolt holes and create an angle washer. when you mount the manifold you'll see what I mean. it's an easy mod and it will seal up if you are careful.
Also if the injectors are for the 305 you'll want to add (or make) an adjustable fuel pressure regulator so you can turn up the FP to make em work on the larger cube engine....
I had a friend put a 350 crate engine in his 305 car, it worked great, just had to get a adjustable fuel pressure regulator to bump the pressure up, otherwise the injectors are not large enough to use the stock pressure.
