need help asap
Old 02-22-2005, 07:17 PM
yungn's Avatar
Default need help asap
I was making my 4th pass at the local track this weekend and the car was fixin to make its 1-2 shift and took it all the way to 7000 RPM's before switching. I can still drive the car but there is no 1-2 shift, it goes straight to 3rd now. I'l drive it to about 2500 RPM about 20 mph , let off the gas and get back in it to be in third. What do yall think is wrong? I went and got estimate on rebuild for the 4L60E and that **** is expensive as hell. Any suggestions?
Old 02-22-2005, 09:19 PM
GregWS6&z28's Avatar
you went to...... 7000 RPM's????????!!!!!!????????
Old 02-22-2005, 09:34 PM
yungn's Avatar
damn close to it
Old 02-23-2005, 07:42 AM
kevredz's Avatar
Do you have a temp gauge? If so, did the tranny get hot or does it get hot driving around town? Does the fluid look dirty or smell burnt?
-Kevin
Old 02-23-2005, 07:54 AM
Z'mnypit's Avatar
Mine did that, I burnt up the clutches in mine. I had no 2nd gear after racing, I had to drive around with it shifting from 1st to 3rd for awhile until I could save up enough money to buy my Rossler 4l60e
Old 02-23-2005, 09:07 AM
lt1dave's Avatar
sounds like you smoked the band, in which case you would also have n 4th, or possibly the sprag. Either way, its time to rebuild
Old 02-24-2005, 07:49 AM
DRACO911's Avatar
You could have also blown one of the rings in the 2nd Piston housing. I did that to mine, and it started doing the same thing. Until it cracked the case.
