Buying n2o... Making sure I have everything... Help/Advice Welcomed!
Old 02-23-2005, 11:40 AM
ABadMother1999's Avatar
Default Buying n2o... Making sure I have everything... Help/Advice Welcomed!
I am planning on buying a NX single nozzle kit (wet) and a Gen-x 2 upgrade. I have a 1999 Camaro z28 (M6) and was curious if there was anything else you think I should get like a window switch or something along those lines or something to make sure I dont blow my motor up.
Thanks for all help and suggestions in advance!
Old 02-23-2005, 11:59 AM
silverZ98's Avatar
window switch,NX filter all ways a plus, TR6 NGK plugs
Old 02-23-2005, 12:00 PM
freakynipples69's Avatar
window switch is #1 for a M6
Old 02-23-2005, 03:25 PM
Chicago Z06's Avatar
Its up to you on how much you spend but a Ramcharger Timing Computer works better than a window switch and you can take timing out as well... and it has a delay feature... buting all that separately will cost way more than the unit... also DEFINTILY put fuel and N20 pressure gauges where you can see them.. yo udont' wnat to spray with too much pressure ( in the summer pressure can go through the roof) as well if your fuel pressure is dropping you want to knwo that as well.. (clogged filter, weak pump etc) other than that.. DON"T spray under 3k RPM, and ALWAYS run good fuel... you can never be too safe... good luck!!
