Got Draglites Mounted....without grinding???
....for the most part. This is on an LT1 car. The right rear rubs noticeably on a test drive and the left scrapes the caliper in only one spot. I am somewhat concerned as to why they fit this esily. Could it be because the rear pads are worn down so much, or is it just easier to fit a 15x8 (5.5bs) on the LT1 rears???
thanks
thanks
They should clear easier because the LT1 brakes are smaller. If the pads are worn a lot that may cause interference later when you put new pads. I'd grind them a little extra just in case of that.
