Accel gen 7 question
can you hook this into the stock dash i have the stock dash from a 2002 camaro and was wondering if the tach would still work off it? also could i make a transmission control out of the stock engine and trans harness with the stock pcm. what all would i have to hook up? tps, crank and cam sensors, how many would i have to hook into to make it work?
no first hand expierience...yet but I will be installing one in my car in a few months. from what i've read on the forum the gauges can be made to work by installing another temp sensor on the passenger side cylinder head and by sharing the crank signal. As for using the stock computer for a transmission controller i don't know. i was planning on running the controller that TCI makes
gary
gary
