how can u differentiate !
Old 02-24-2005, 11:19 AM
FiveSevenEagle's Avatar
Lightbulb how can u differentiate !
after installing a camshaft with a little bit choppy ideal i started to think what if the spark plugs need to be changed or any electrical problem occur MISS FIRING for example .. how can i differentiate between a choppy idealing and a miss fire i know it sounds weird but how !!
before the cam u can easily notice the miss firing .. cause the engine is running smooth .. maybe ill disable one spark plug to see how is it going to be
Old 02-24-2005, 11:48 AM
PREDATOR-Z's Avatar
With a datalog you can see the missfires. As far as audible detection on a cammed (choppy) car it will be much harder. Tach. needle movement.
Old 02-24-2005, 01:23 PM
equandt's Avatar
If you have a miss fire won't you through a code as well?
Old 02-24-2005, 01:55 PM
psykoTA's Avatar
Only for multiple misfires.
