Air/Fuel Gauge
With the Autometer gauge I had it worked great spliced into the PCM. But when I tried to do that with the Dynotune O2 meter it always read atleast .1mv low so it needed to be connected to the O2 sensor. If you want to splice you can splice PIN #69 on the blue connector at the PCM for bank 1 or PIN #66 for bank 2. #69 is a purple wire with a white stripe and #66 is just purple if I remember correctly.
