General Maintenance & Repairs - problems starting
View Full Version : problems starting
Quikws6
02-25-2005, 05:53 PM
alright heres the case im running into.....any help/ideas are welcome....alright ive got a 95 lt1 A4 swap into a 95 s10......lt1350.com spliced my wiring harnesses together....just put on a new optispark and it ran great for the first two days then i shut it off and it wont start back up.....so i waited for the motor to cool and it started right back up ran for about 10 min or so then shut it off and now it wont start at all....i have fuel and the injectors are spraying....spark plugs are also brand new....my ? is what could be causeing this????
Alex94TAGT
02-25-2005, 07:19 PM
Few questions:
Do you have an SES light? Might be a good time to scan for codes. (Edit -- duh, motor swap. Do you still have the ALDL port in the wiring harness?)
Does the motor turn over when you turn the key? Or is it just completely dead?
Does this only happen with the motor warmed up? I would tend to lean towards an ignition problem. Sometimes the ignition control module / coil start to screw up once they get hot. But, it could just as well be a wiring problem -- did you check for any burnt wires (around exhaust and whatnot)?
I'll let someone else step in...
Quikws6
02-25-2005, 07:28 PM
i also replaced to ignition module to no avail.....it still turns over just does not crank
SAPPER
02-26-2005, 10:57 AM
I agree w/ Alex, ALDL= scan
