Ported LS6 Heads vs AFR 205 Heads??
Old 02-25-2005, 06:29 PM
fuzzyfine's Avatar
Default Ported LS6 Heads vs AFR 205 Heads??
Which would you suggest, Ported LS6 Heads or AFR 205 Heads. If you go with the LS6 heads do you get them polished? Is there a power difference? What are the advantages of going with one over the other.
Your help would be greatly appreciated
Old 02-25-2005, 06:48 PM
DanZ28's Avatar
Not to a abrassive, I noticed this is your first post, I would suggest using the search button on this and you would find all the answers you need...
Old 02-25-2005, 07:30 PM
ArcticFormula's Avatar
AFR
Old 02-25-2005, 07:34 PM
SlickVert's Avatar
AFR all the way
Old 02-26-2005, 08:04 AM
LS1TECH Sponsor
badpewter-z's Avatar
afr here as well
the extra torque is worth it
Old 02-26-2005, 10:02 AM
mike c.'s Avatar
arf's here to. the search button is great,but you don't always find what you are looking for.
Old 02-26-2005, 02:36 PM
JZ'sTA's Avatar
On this topic you would have found more then your looking for.
Old 02-26-2005, 05:39 PM
6.0vette's Avatar
I think i would depend on what your doing with the car.
A car that does mostly street action,definatly AFR, but
a drag monster would probably be better off with killer LS6
heads.Now worked AFR heads might be a different story,
although Tony says youll have no warranty if another machine
shop works them.
Old 02-26-2005, 09:17 PM
HAMRHEAD's Avatar
AFR heads compared to what, stock LS6 heads or Stage 2, Stage 3 LS6 heads?
Old 02-27-2005, 04:18 PM
jrp
SN95 Director
jrp's Avatar
whats the application and cam?
Old 02-27-2005, 04:34 PM
Nate_Taufer's Avatar
ditto, what cam? i would rather run the gmpp cnc ported ls6 heads.
Old 02-27-2005, 07:10 PM
gaga's Avatar
https://ls1tech.com/forums/showthrea...&highlight=afr
here ya go, i asked this 2 months ago.... a good read...
Old 02-27-2005, 09:14 PM
NASTE_SS's Avatar
Default ls6 heads
i would run the ls6 heads if they are ported by someone who knows what they are doing. i've seen ls6 heads flow 360 and that's alot better than any afr head i've seen.
Old 02-27-2005, 09:36 PM
1CAMWNDR's Avatar
At what lift and what port volume??
Old 02-27-2005, 10:27 PM
NASTE_SS's Avatar
at .660-.700 somewhere in betwwen there and to give you the port volume i'd be getting myself in trouble with my teacher. i no enough details on them but nothing i'd want to share
Old 02-28-2005, 06:36 AM
SAM98WS6's Avatar
Good ported LS6s will perform better than out of the box CNC AFR 205s...provided you get them done by a great porter..like Rapid or MTI.
To avoid mistakes get the AFRs and sleep better.
Old 02-28-2005, 07:38 AM
1CAMWNDR's Avatar
For some reason I do not see the need for flow numbers over .600" lift since most LS1 cams (especially those expected to have any street manners) do not have that much lift. Unless you are building a race only motor that will never see street time.
I say go with the AFR 205 and if you are loosing 10-20 cfm over some worked LS6 heads, enjoy the better torque that the small AFR ports have.
Old 02-28-2005, 09:26 AM
Big-DEN's Avatar
Question is what works better with the intakes that are currently being used:
LSX, LS6 intake...
The AFR's don't seem to be doing bad at all and delivering some heavy numbers
for moderate camshaft configurations ( IE: 224@.05" )...
Quick Reply: Ported LS6 Heads vs AFR 205 Heads??
