Gears & Axles - 4.10 gear question?
View Full Version : 4.10 gear question?
02WHITEZ
02-25-2005, 10:04 PM
in 6th gear at 70mph my tach reads 1800 is that right i changed the ratio with my efilive but it just doesn't look right also i have changed from 16 x8 wheels to 17x9.5 would that make difference with computer thanx in advance
justin
WAHUSKER
02-26-2005, 11:13 AM
An M6 has a .5 ratio 6th gear. According to my spreadsheet, you should be turning 1880 rpm @ 70mph. My A4 turns close to 2500 in 4th gear, and it's .7 ratio. This is with stock 25.6" tires.
noah89
02-26-2005, 12:45 PM
I think you're okay. I read about the same thing.
2001NBMZ28
02-26-2005, 01:28 PM
Sounds about right - you can measure the exact tire diameter and check it against the calculator at www.f-body.org/gears/ Even when replacing the stock tires with the same size the diameter can change a little from manufacturer to manufacturer.
Proud2bSS
02-26-2005, 04:08 PM
justin You should be okay. My Predator gives me a higher rpm number than the 'idiot light' OEM tach (they are not that good).
02WHITEZ
02-27-2005, 12:51 AM
thanx guys for all the info....damn i kinda wish i would have gone with 4.30
