car smokes at idle
Old 02-26-2005, 06:24 PM
WS6FirebirdTA00's Avatar
Default car smokes at idle
ok this is for my girlfriends car, its a 98 eclipse, yeah i know pos but still. i didnt know if there was another forum to post this in so mods if there is sorry and please redirect this thread.
at idle the car smokes sometimes very very bad. sometimes it wont. i put a thicker oil in it and lucas additive. helped a lot but it smoked on her again the other day when she was idling talkin to me. when she gives it gas it clears up a little bit but smokes a little bit but idle is real bad. i dont know if the rings are shot or what but she doesnt drive the **** out of the car at all. i was wondering if maybe some valve seals or something since it was at idle a lot, but then again i really dont know thats why im asking about it. let me know what you guys think. if its something on the top end that i can do ill do it but if its tearing appart the bottom end ill let someone else mess with that haha. let me knwo what you all think, like i said sorry if its the wrong spot
Old 02-27-2005, 08:55 AM
PREDATOR-Z's Avatar
It is the wrong forum alltogether, unless she has an LS1 in that Eclipse.
Old 02-27-2005, 08:57 AM
yeah i know, but i was just hoping someone would beable to tell me what would make it smoke like that. should smoke for the same reasons right
Old 02-27-2005, 09:41 AM
Raise's Avatar
what color is the smoke?
Old 02-27-2005, 09:50 AM
fast98's Avatar
refresh my memory, is that car turbocharged? and what color is the smoke? u can do a cyl leak down test to see if the rings are bad. is it using oil?
Old 02-27-2005, 09:54 AM
yes its using oil, no its not a turbo one. its burning oil the smoke is blueish
Old 02-27-2005, 10:01 AM
fast98's Avatar
do a leak down test on the car. u can also replace or check the pcv valve.
Old 02-27-2005, 10:16 AM
i did the pcv valve already, ill have t get a leak down test done then i guess and see what that shows. thanks
Old 02-27-2005, 10:35 AM
LS1TECH Sponsor
mikey's Avatar
Valve seals and guides. Mitsu's are famous for that.
Old 02-27-2005, 10:44 AM
thanks man
