Need help setting up fuel system for FI and nitrous
Old 02-26-2005, 09:52 PM
I8URLS1's Avatar
Default Need help setting up fuel system for FI and nitrous
I just need someone to make me a list of a very good setup for what I'm doing.
355 LT1 with T trim and FMIC. shooting for as close to 700rwhp on pump gas as possible. On top of this is going to be a 200 shot but that will be on a race gas tune obviously. I only want to run the stock tank. Also what size injectors am I going to need? Just please make me a list that I can basically print out and buy this stuff. I'm hearing product engineering is good for the street? This car will be street driven a lot. Thanks in advance, Jarred
Old 03-02-2005, 11:20 AM
I8URLS1's Avatar
anyone?
Old 03-04-2005, 11:39 AM
1FASTLS's Avatar
I would look into the racetronix fuel pump and wiring kit, or just get a Holley/Walbro 225lph pump and wiring kit from racetronix, the pump should handle 775 horses, but the wiring kit helps keep voltage drop after 5500 rpm per what some tuners have told me and the charts I have seen. Also injectors don't be to worried when selecting a little bigger is safer a good tuner can adjust them in, but her is a site that may help
www.motorsportdigest.com/perform2.htm Hope this helped Good luck
Old 03-04-2005, 12:25 PM
kcshaner's Avatar
I have essentially the same set up as you, with those numbers get a Rachtronix intank, MSD boost a pump, good inline (I did bosch 420) and 75 lb injectors
