2.05" valves in 5.3 heads
Any problems?
Will likely be milled about .010" ANy concerns with P to V clearence? Sure, I'll check on re-assembly, but I want it to be a just in case inspection not a prelude to a do over!
I can shift faster than you.
It is advised to go to a larger valve seat when upgrading to 2.055" intake valves. With properly porting/chamber work, the 2.055" valve will show excellent gains over the stock valve.
Jason
Jason
