Help with NX bottle heater
The pressure switch on my NX bottle heater doesnt seem to be working. I was checking to see if it works, and wired it up as the instructions showed. The heater did not get warm when I activated it. If I bypassed the pressure switch the heater worked fine. I hooked up the pressure switch to an ohm meter and it read infinate resistance (open). The bottle is empty, does the switch have to see some kind of pressure to work? Any help is greatly appreaciated. Thanks,
Andy
Andy
Closed ex-Sponsor Account
Hey Andy the switch is bad. It should have continuity right out of the box. Any pressure below 900 and the contacts are suppose to be closed. If it is a new unit I will warranty the switch.
Ricky
Ricky
Andy
Andy
Ricky
Ricky
Also how much does a new one cost?
It is not new. How do you think it went bad? .
Do you think I can open it up and fix it?
The part is not repairable being epoxied in once bad its junk.
Ricky
