Going 12 bolt, new gear ratio?
I'm getting ready to order a 12 bolt for my 2002 Z28, which has run high 10's on a 125 shot, 127 mph. It currently has a stock rear with 3.23 gears, and its an A4 car. I do have a big stall, and H/C, as well as the usual bolt ons. Would a gear change do anything for me, and what ratio? This is mainly a street car, so no monster 4.30 gears for me. I was thinking maybe 3.73 or so.
Also, if I did the rear swap with a new gear ratio, could I even drive the car or would it need tuned immediately? I plan to have a custom tune done, but I will probably have to drive it a short distance. Thanks for the help!
3.73s. Yes, it will run, but your speedo will be off, your ABS and ASR will likely throw a fit, and your trans shift tables will be off. But, it should be fine for a SHORT while. Also, are you set on a 12 bolt? You might also look into a 9 inch. Just a thought. Good luck.
I plan to run 26" tires, but I'm also wondering if they will be tall enough with a 3.73 gear or if 28"s will be required. I have an A4, and the cars been 10.85 on a 125 shot, 127 mph. I know on my GN I had to run 28's because I'd run out of gear and have to shift into OD which sucks. Will 28's even fit a 2002 Z28? The 26's are on now and they look awful close to the rear bumper cover as it is, I can't see 28's going on without body mods.
I'm not set on the 12 bolt, I plan to order my rear next week and will be getting it from Billingsley racing, since they are 45 mins. from me. I plan to talk to Jay about what rear and what gear is best.
26" tire@6500, 1:1 drive, 3:73's you can go 134.8mph
everything the same except a 6000 redline your at 124.4 mph
everything the same except a 6700 redline your at 138.9mph
now remember when you have a stall convertor and your at top end, i dont think it 100% locks up and theres usually a 3% slippage so figure if yoru redline is 6500, 134mph * .97 (3% slippage) your actual mph is 129.98mph.
I'd up the converter slip factor to at least 5%. Not many converters slip that little running NA, and with a 125 shot the slip is likely to increase. Also allow for the fact that you'll be at WOT crossing the stripe so your final MPH may be a tad higher than the measured trap speed.
