Drag Racing Tech
Tire and wheel combo
Old 02-28-2005, 04:36 PM
Racer8102's Avatar
Default Tire and wheel combo
I am wondering which tire and wheel combo (brand and sizes) everyone is running on their cars which are mainly used for drags. I currently have Torque thrust 2's 17x9 and 17x11 and man those things are heavy, I am slowly converting to a full drag car and want to know more about a good lightweight setup that will fit correctly. Thanks
Old 02-28-2005, 05:42 PM
LS1TECH Sponsor
Steve Burger's Avatar
Weld Pro Stars. 15x3.5 front and 15x10 rear. 15x26x11.5 ET Street on the rear.
Old 02-28-2005, 05:52 PM
Loudmouth LS1's Avatar
Weld Draglites
15x3.5 up front and 15x10 (7.5 BS) out back. You will need to grind the **** out of the calipers out back to make the 15x10's fit, and use a spacer up front for the skinnies, or you could grind them too if you wanted. I run pepboy futura 165r15 "beetle" radials up front (cuz I still drive the car on the street and they're really cheap, like $24 a piece) and at the track, I run 28x10.5x15 M/T ET Drags (they are the ****) out back!!!!
Old 03-01-2005, 09:21 AM
Racer8102's Avatar
Thanks for the info. I heard if you run the 16" wheels they require a little less grinding on the back, is this true? Also where is the cheapest place to get these wheels and what about bogarts?
Old 03-01-2005, 03:04 PM
I don't know about the 16's, but for a drag car, you want 15's, you want more sidewall to be able to flex, helps hooking. I got mine from jegs. Plus I think the 16's are the xp style, which are heavy from what I hear!
Old 03-02-2005, 08:42 PM
B-MAN's Avatar
Bogart 15"x103/8" with Hoosier 27" street slicks.
Old 03-03-2005, 11:54 AM
Race your car!
JL ws-6's Avatar
Bogarts.. no grinding required.
