stock pushrod/lifter differences
i searched and searched but found nothing, so if this has been asked before i'm sorry but...
what, if any, are the differences b/n the stock LS1 and the stock 6.0 pushrods and lifters? i'm about to begin rebuilding a 6.0 and need to know.
If the ratio of the rockers are the same, it shouldnt make a differance as long as the bolt on the same, and what does the cam call for as far as roker ratio .As far as pushrods always use an adjustable pushrod length checker any time you change from one motor to another if your with in 0.050 length you should be ok.
