Best sixty foot acheived with a TCI SF3000 and SSF3500?
Old 03-02-2005, 01:28 PM
CHRISPY's Avatar
Default Best sixty foot acheived with a TCI SF3000 and SSF3500?
Hi guys,
Please post your best sixty foot time and 1/4 mile data from either the TCI SF3000 or SSF3500
Please also list:
Mods:
Gears:
RWHP/RWTQ:
Tires used:
drivability:
lockup: (How well it locks up for you)
tranny cooler used: (If any)
Old 03-02-2005, 01:39 PM
Moderator
jimmyblue's Avatar
Look for posts by Colonel, he had those in his 'Vette at
one point. I have no data on my SF3000 and it will probably
be coming out before I ever get to the track.
Old 03-02-2005, 03:17 PM
CHRISPY's Avatar
why are you taking it out? any problems?
Old 03-02-2005, 03:31 PM
JaSSon's Avatar
I know a guy on here "old blue", he cut a 1.58 and ran 11.98 with lid, headers and off road y, pulley, and TCI ssf 3500 on Nittos.
Old 03-02-2005, 04:11 PM
Moderator
jimmyblue's Avatar
I have had a nagging clutch slippage problem from about
day 3. Some or all of it being my fault for putting B&M
Trick SHIfT fluid down it, but even so. This was my first
converter. Since getting it I've figured out for my style
of driving and current / upcoming mods I want something
with a higher stall speed, lower STR, higher efficiency and
or course a clutch I can pull a trailer with (not that I will,
but that kind of strong). I was moved to action by that
"other board" GP and ordered up a custom one built to my
"wish list". I've been having to keep upping line pressure to
get the clutch not to slip bad on the highway and that's
not something I can keep doing indefinitely. So this came
around at a good time.
Performance wise the TCI has been fine, but the 3000 seems
to "hold the motor down" just a little and the 2.2 STR is just
more than my street tires need. If you have taller gears or
better hooking tires than GS-D3s then the STR will help.
On 3.42s I just lose traction at 1/2 throttle; what help is
that? So I spec'd out something I think is more in line with
a traction-limited, power-limited low-mods car, and will see.
Old 03-03-2005, 01:21 AM
LS1_PNYTAMR's Avatar
1.62 on worn out et streets.. 3000 stall, 150 shot with lid/cutout at the time only... with cam and spray and gear and headers, hoping for 1.55 60 times if the 10 bolt holds up.. however i may shortly afterwards upgrade the stall to 3500 to suit the all motor times a lil bit better.
Old 03-03-2005, 10:01 AM
koolrayz's Avatar
I cut the times in my sig with the SSF3500
Old 03-03-2005, 12:57 PM
Red 01SS's Avatar
SS3600. My mods are in my sig but I got a 1.71 on BFG's and the most I could give it off the line was 1/2 peddal. Anymore and I blew the tires off...
Old 03-03-2005, 03:19 PM
Nsty98LS1's Avatar
1.759 60' on street tires. mods at time were free mods, lid, loudmouth, and TCI SSF3500.
Old 03-04-2005, 10:20 PM
X_03_Cobra_guy's Avatar
I also have the SS3600. That converter will get you easy 1.50 60' on ET streets.
It hits very hard. It will easily spin all makes of drag radials at just 1/2 throttle
just like the man said. Very streetable converter though. Just don't even think
of punching it at a red light!
Old 03-05-2005, 12:43 AM
4mula's Avatar
1.81 60 times and 12.73 e.t
mods at the time, 1.85 rocker arms, magnaflow exhasut, nittos converter and a lid.
also my best 60 was with not that great traction.
Old 03-05-2005, 06:37 PM
CHRISPY's Avatar
Cool sounds good!
Anyone have the TCI 3500 and wished they went smaller?
I am still torn between the TCI 3000 2.2 STR and the TCI SSF 3500 with 2.5 STR. (I have 2.73s at the moment)
Old 03-05-2005, 07:01 PM
sleeperstyle's Avatar
3800 and 2.73's- LOVE it, only thing i hate is the gas milage when it is unlocked
replied to pm also.
i had a 3500 and went bigger to the 3800, if i had any different gears (like 3.42 or 3.73) i'd went at least 4000 or 4200.
if the car is DAILY driven and not raced much i could see you wanting to go smaller though, for the gas milage factor alone. you have to be pretty well into the throttle for it to move, no ***** footing the car around anymore(ESPECIALLY with the 2.73's-)
forgot to mention- you will NEED drag radials with this converter. it hits pretty hard.
Old 03-05-2005, 09:34 PM
Red 01SS's Avatar
or anywhere up to 50 I still spin....I have got it to spin on the highway from 60 once as well
Old 03-05-2005, 09:52 PM
DietCoke's Avatar
1.63 is my best dead hooking on 4.11s with the 3000SF
Old 03-06-2005, 11:20 AM
CHRISPY's Avatar
1.63 is quite good for that small converter. The gears probably helped a bit in that regard too.
Eventually I am going to be running DR's so I think the SF3000 would probably work best. (Car is a street car with very limited track use)
