Drag Racing Tech
How does this sound, A4,3.42, 26" tire, 550 rwhp
Old 03-03-2005, 11:34 AM
Y2K2LS1's Avatar
Default How does this sound, A4,3.42, 26" tire, 550 rwhp
Anyone running anything similar to this? Thinking about a stall around 3500 with a low STR for high efficeincy up top. Car should make 550 rwhp w/ convertor locked at minimum. What do you all think it would run? Cross the traps at? I'm planning on a conservative high 1.6 to 1.7 60". Will be on a 26" w/ 3.42 gears.
Old 03-03-2005, 01:44 PM
DMcRacer's Avatar
I'm running high 10's with 3:42's & 412hp locked. But I have a hard hitting Yank 4600.
Old 03-03-2005, 06:15 PM
Y2K2LS1's Avatar
Tell me more about your setup. What rpm do you cross the traps at? I'm assuming this was on a ET street radial? 10bolt or 12bolt?
Old 03-03-2005, 06:44 PM
Slacker's Avatar
Im running 3:42's in a 10bolt, Vig3200, 26" MT Dr's, Cam only not sure of HP but under 400 im sure, Current best is 11.80 @ 115.87 with a rich tune & mid 1.6 60'. So with the Hp you posted you'll be smoken low 11's if not better and MPH in the 120's.
Old 03-08-2005, 05:57 PM
T/ALT1's Avatar
I am making about 550-575rwhp with a 175shot, 3.42's in the stock 10bolt, 3800 Vigilante and have run 1.50 60' to the tune of 10.23@132mph and 10.24@131.8mph back to back a couple weeks ago leaving easy on motor then spraying out 10-20' in the 60'. I am very pleased with this setup. I am going to put a better rear in the car and try leaving off of the transbrake and 175HP NX. Later
Old 03-10-2005, 08:56 PM
Got Me SOM's Avatar
that car with a conservative launch should do a 10.7-10.8 @ 127 at full weight. faster if weight is taken out.
