what is a "sumped" tank?
Originally Posted by prostock_bigblock
small light weight tanks , used usually in carb
Whats the point of having a sump? Just to feed a external fuel pump? Do you need to have a sump if you want a external fuel pump?
Thanks
P.S. sorry to jack your thread...was curious also
Thanks
Thanks
Thanks
Originally Posted by Beast96Z
Not really. A "sump" is a tub like pan that is welded to the bottom of your metal gas tank. It has a bung coming off to feed a external fuel pump. For our cars, lots of people, including myself" buy the metal tanks out of the 94-97 F-cars, weld on the sump, and run your external fuel system. Some people have used bulk head fittings on the bottom of the plastic tanks and had good luck. Here is the metal version: http://www.jegs.com/cgi-bin/ncommerc...88&prmenbr=361
Originally Posted by wideopenTA
How much would a tank like that run out of an 94-97 F car? i am looking to run an external pump on my car this year and have the plastic tank!,,, and if you have any more info on converting a plastic tank with the bulk head fittings please let me know,,,, and which would be better im guessing the metal tank, but whats your take?
Its not just 97 or older tanks......
I used my 98 METAL fuel tank...... i bought the Competition Engineering Fuel Tank Sump for $62 and paid someone local to weld the sump on after baffles were cut under it for about $75. That was the hard one.......
Heres some pics of it out of the car.
Kyle
Kyle
Thanks for all of your help guys!,, my motor is out so i might as well just pull the tank too to do the bulk head fittings!, does anyone have any pictures of the bulk head fittings on a tank?
SSU'S Vice Mod
Where would you run the return line to? Factory position for existing fuel pump? What was the latest year they ran metal tanks? 98? 99? What baffels do you speak of Kyle? Also, any concerns about fuel fumes igniting while cutting/welding?
I used my stock feed as my return and let the fuel fall back into the tank. I set my FP reg. on the old stock feed now return with a tube, nut, sleeve.
I believe 98 was the latest yr for a metal tank.
The sump kit has you cut 3 holes(baffles) and then weld the sump on under that.... i didnt take any pics of that sorry.
I beleve you saw my other thread after this but the guy filled the tank with argon after i let it sit out side full of water for a few days.. then he welded it.
Kyle
Kyle
Kyle
Mike
SSU'S Vice Mod
so basically, you only cut a few holes into the tank to let it drain into the sump. Gotcha now. I thought you had a hole the size of the sump part. Honestly...I think going the sump way provides for so much more access to more fuel when doing a multi stage project and you finally need it.
SSU'S Vice Mod
Kyle how much total do you have into your tank, labor and cost of the sump part?
Yeah that too? Does any one of the suppliers sell them? I think someone said they do. I might be a knuckle head and want to do all of it myself or with the help of friends but sometimes it's easier, cheaper and better to source stuff by the time you factor in time.
SSU'S Vice Mod
I have a drag gas tank from Speed Inc, I think they retail in the $375 range.
John...does that use an intank deal? Is it a fuel cell or is still a tank? How much fuel does it hold?
Could you theoretically "sump" a plastic tank?? if so, how would you go about doing it?
Here ya go PSJ.
Its a Competition Engineering sump kit and was $61.88 and i ordered other stuff at the same time so the shipping wasnt much.
The labor was $75 and that was for the welding and paint to finish it up.
I got the idea from Harlan and asked him what he used and went for it.
So i have about $140 in it.
Kyle
Kyle
