Hesitation after new plug install
Old 03-03-2005, 06:39 PM
twocam99's Avatar
Default Hesitation after new plug install
A real new newbie here. Nice board. I just changed plugs in my 98 with new ngk tr55s and now there is about a one second hesitation when I step on it. I had gapped them at .06 then pulled them out and regapped to .05, and there is still a hesitation. Is .05 the right gap? any thoughts? Thanks
Old 03-04-2005, 02:20 AM
WS6 RULES's Avatar
[QUOTE=twocam99]A real new newbie here. Nice board. I just changed plugs in my 98 with new ngk tr55s and now there is about a one second hesitation when I step on it.
Just gap them to what is recommended. The plug gap will not cause the hesitation. I suspect you may have a vacume line or something off. You may have bumped something off while your were working or you forgot to put something back that you took off. I use the AC Delco Iridium plugs. You can't gap them. Just put em in and forget about them. Good luck
