Drag Racing Tech
spare tire rim as skinny rim?
Old 03-04-2005, 09:00 AM
ace68's Avatar
Default spare tire rim as skinny rim?
Can you use a spare tire rim as a skinny with a different tire on it? Or is it just too heavy?
I was moving some stuff around in the garage and got a thought?
Old 03-04-2005, 09:09 AM
Z06PSI's Avatar
Got a thought of the wheel collapsing at 120 and you not surviving.....
Old 03-04-2005, 09:10 AM
ace68's Avatar
oh the rim is **** too?
Old 03-04-2005, 09:11 AM
Z06PSI's Avatar
I just wouldn't trust it.... buy some draglites for 150.00 off ebay....15x3.5's
Old 03-04-2005, 09:14 AM
ace68's Avatar
dralights fit without mod?
Old 03-04-2005, 10:45 AM
LS1_PNYTAMR's Avatar
with spacers the should clear up front actually from what ive heard.. but then u want to use longer studs ect or....... chance things.
Old 03-04-2005, 12:02 PM
GM Muscle's Avatar
I wieghed the spare for somebody and it was around 28lbs or so. I still wouldn't run on them though. I picked up my Prostars, tires, spacers, and lugs for $350 off ebay. With the Prostars you'll need a 5/16" spacer to clear the calipers. You really should get some ARP studs too, I have some but never got around to installing them. You'll also probrably have to run an open lug nut with you regular wheels and longer studs or maybe you can find an extra long acorn style lug.
Old 03-04-2005, 12:39 PM
GM Muscle's Avatar
BTW: I just wieghed a Prostar. The wheel, 165R tire, lugs and spacer was almost exactly 25lbs.
Old 03-04-2005, 04:30 PM
DietCoke's Avatar
The wheel alone weighs 7.5 pounds. That leaves us with a 16 pound tire, and 1.5 pounds of spacer/lugs/centercap. Sounds about right.
Old 03-09-2005, 09:30 PM
Black8Banger's Avatar
w/ 15x3.5 you gotta run a 5/16" spacer and get the long shank style lugnuts from weld!
Old 03-09-2005, 09:46 PM
LS1TECH Sponsor
Magnus's Avatar
I believe the spare is a 14" wheel.
Old 03-09-2005, 11:16 PM
Navy David SS's Avatar
The "spare tire" is meant for 55mph. If you actually intend on going only 55 in the 1/4, than by all means use it. Otherwise, spend the money to get the right wheel and tire. Play it safe out there. These car are bad *** and aren't meant to be joked with.
David
Old 03-09-2005, 11:39 PM
LS1TECH Sponsor
Magnus's Avatar
I think he's asking about usign the wheel itself with a different tire.
Will be hard to find a 14" tire that is speed rated.
Old 03-10-2005, 01:24 AM
Moderator
xp3nd4bl3's Avatar
Some of the '94-'95 Cobra guys use spares for skinnies since no standard skinny fits their brakes. I wouldn't do it though, especially when you can get a set of draglites with 165r15's for cheap.
Old 03-10-2005, 07:19 AM
7 Second Club
Villain281H's Avatar
Location: Gainesville, Florida # of drag strips runs: ?!?!?
yep, get some real front wheels. Mustang guys used to use spares for a while back in the days, until race organizations found out and outlawed them from being used.
Derek
Old 03-10-2005, 08:09 AM
ace68's Avatar
Thanks everyone I am looking at a set of skinnies, real ones, now I hope I can snag them.
