Electric trans temp gauge?
Is that what most people running a trans temp gauge are using or do you use the mechanical gauge?? I'm just going to have it to be safe and they look cool, this is a 98% street car and will have a trans cooler installed when the converter goes in, so the gauge doesn't have to be a 100% accurate, also the electric gauge in nearly 2/3's less than the mechanical one!!
you can change the bulb out to any color you want. I changed out my bulb on my 2 1/16" gauge to a hyperwhite. The bulb is a 194 peanut bulb like that's used in the clear corners and rear side markers
I gave my friend the red slip covers for the clear bulb that comes with the gauges and it matches his interior lights very very well
Originally Posted by 99'Formula
Auto Meter
