First run with the new Converter :)
First off gotta mention that the our track is at 5320ft, and DA was 5459ft, which sadly, is about as good as it gets here (can get to 8000ft in the summer ) Cost me about 50hp on the dyno, So i'm actually making around the rated hp of 305 at the crank ;p.
60ft: 2.101
1/8: 8.969
1/4: 13.92
mph:99.919
DA corrected for 5459ft would be 12.91@105.76.
I did get a couple 100mph traps, probably from spinning a little too much off the line, but that was the best ET. I can't even believe how much of a difference that converter makes, much different than a manual car, it's just one long constant pull.
FYI, I made a run before the converter. With only a lid, ran a 14.39@98 w/a 2.22 60ft.
60ft: 2.101
1/8: 8.969
1/4: 13.92
mph:99.919
