Tap Tap (like knock, knock)
Old 03-06-2005, 04:50 PM
ssheets's Avatar
Default Tap Tap (like knock, knock)
I want to pick up some taps to clean up the threads on my heads and block prior to re-installing anything. What taps do I need?
Head bolts (studs)
Header bolts
oil pump
water pump
intake manifild
I'd like to clean them all up and then use either loctite or antisieze as required.
TIA
Old 03-07-2005, 08:42 AM
LS1s R US's Avatar
Put a rag on a screw driver and clean to holes out and blow it out with a high pressure air blower thats the way I do it. The coolant in the bolt hole is the main concern!
Old 03-07-2005, 10:57 AM
ssheets's Avatar
Yeah, that works 99%, but it's nice to have a tap handy if you really need to clean a set of threads.
Old 03-07-2005, 12:08 PM
98TXFBODY's Avatar
Location: Used to live in South Texas, Now in North Carolina
There is a tap and die kit mad for a ls1. Not sure where to get it......maybe a dealership?
Old 03-07-2005, 12:38 PM
ssheets's Avatar
That would be cool, I can call my dealership and ask.
I was looking just for the 3-4 common thread sizes to have on hand just in case. Nothing worse than buggered up threads in aluminum
Old 03-07-2005, 04:03 PM
99ZEOD's Avatar
Maybe I'm being a little picky but wouldn't you want to use a thread chaser instead of a tap?
Old 03-07-2005, 05:04 PM
ssheets's Avatar
Yes, my mistake...still need the thread sizes
