*PICS* Custom ram air -- lid and FTRA are gone!
Old 03-07-2005, 02:13 AM
Moderator
xp3nd4bl3's Avatar
Default *PICS* Custom ram air -- lid and FTRA are gone!
Since the TSP 85mm lids haven't been available for what seems like years now , we were forced to take a different route-- custom fab. I wanted to do this a while ago after seeing 383LQ4SS's badass setup. Huge thanks to the oxidizr, aka "The Custom Fabber" for building this for me (as well as everything else on my car) Anyway, here are the pics:
Once the pair of square filters come in Rich is going to fab up a couple boxes that mate up to the openings on the SS grille for a true ram air setup. Should be pretty efficient at 120+ mph
Old 03-07-2005, 02:14 AM
Slammed-am's Avatar
Sweet.
Old 03-07-2005, 02:34 AM
BuBbABFP's Avatar
looks good.
Old 03-07-2005, 06:10 AM
!LS1 11 Second Club
SouthFL.02.SS's Avatar
Is air coned into the two ends below?
Old 03-07-2005, 08:14 AM
777's Avatar
i would assume...he said he was going to take air from the grille of the camaro...
Old 03-07-2005, 09:01 AM
Moderator
jimmyblue's Avatar
Tell you what... do this in ABS plastic with a plastic-welding
rig, make it a pretty DIY kit and y'alls could have a business.
Old 03-07-2005, 09:21 AM
SSpeedracer's Avatar
Did you cut the top radiator support?
Old 03-07-2005, 09:28 AM
LSWannabe's Avatar
Nice setup! Keep us informed on the progress.
Old 03-07-2005, 10:05 AM
jerflash's Avatar
ya h they cut thr rad support not somthing that every guy inhere is going to wana do but for a race car its fine
Old 03-07-2005, 10:44 AM
BigBronco's Avatar
man that looks great!
Old 03-07-2005, 10:48 AM
00Z28 Camaro's Avatar
If it dynos well I'd buy that over a LID no 2 ways about it.
Old 03-07-2005, 10:58 AM
badaSS346's Avatar
How are you getting to the grill? I mean did you cut out the support behind it or did you just use those small existing holes that were there?
Paul
Old 03-07-2005, 11:03 AM
EightBall's Avatar
not so sure that everyone wants to get rid of their A/C for that either...
Old 03-07-2005, 12:03 PM
Moderator
xp3nd4bl3's Avatar
Yeah, the support was reinforced with steel plating welded into where it was cut, probably stronger than it was before!
I'll update with pics when it's 100% complete as well as some dyno and ATAP results.
Old 03-07-2005, 01:47 PM
Durien's Avatar
you should polish that tube..lol..
Old 03-07-2005, 02:26 PM
nighthawk71's Avatar
considering it needs ram air to really work the dyno will not show accurate results... Should be about the same..
Old 03-07-2005, 02:56 PM
APeteSS's Avatar
You sure you want square filters? Have you thought about velocity-stack cones? I like the pressurized box idea.
Old 03-07-2005, 04:41 PM
Turo's Avatar
I'm interested in IAT's, I wonder if they will be lower now. I've been wanting to try something similar but i don't have the fabrication skills.
Old 03-07-2005, 07:04 PM
2001CamaroGuy's Avatar
Originally Posted by BuBbABFP
looks good.
the pipe anyways.......think I would try to find something better than the spray painted black sheet metal....
Old 03-08-2005, 09:51 AM
SSCamaro99_3's Avatar
It will be interesting to see how it works out.
