160 Thermostat
Old 03-07-2005, 10:52 PM
LSTSS02's Avatar
Default 160 Thermostat
Anyone know if I change my thermostat to a 160 degree if I will trip the SES light?
Thanks!
Old 03-07-2005, 11:01 PM
DravenMyers's Avatar
Thanks!
It shouldnt as long as you dont leave nothing disconected as in any wires.I just ordered mine today I will put it on with my cam and tuneing
Old 03-07-2005, 11:08 PM
LSTSS02's Avatar
Ok......I was curious as my 97' Ram Air LT1 did trip the SES light........
Old 03-07-2005, 11:14 PM
did you scan it to see why it kicked a code I have changed thermostats on LT's with no problems
Old 03-07-2005, 11:31 PM
LSTSS02's Avatar
no I sold it awhile ago after I blew the motor from too much vortech boost.
Seems this LS1 is pretty quick though....02' SS 345HP (Stock)
Old 03-08-2005, 10:26 AM
LS1s R US's Avatar
Know alot of people running the 160 & no one has had an SES light on.
Old 03-08-2005, 11:31 AM
Buceman's Avatar
If you take your car to an Autozone (or something similar) They'll tell you the code and what it means for free. Then post that and we can help more.
Old 03-08-2005, 12:06 PM
HAMRHEAD's Avatar
160 thermo won't trip a code
Old 03-08-2005, 12:10 PM
ArcticZ28's Avatar
Def. shouldn't throw a code. And, it's not going to do much at all for your car until you program your fans to turn on at 160 as well. I used a hypertech to do that when I got my 160 stat and it runs ~185 all the time now. Before it used to run 195-200 consistently.
Old 03-08-2005, 12:13 PM
Y2K SS's Avatar
Is it even worth putting in on a LS1??
Old 03-08-2005, 12:14 PM
Schantin's Avatar
Schantin
2002 Camaro Z28 M6
Old 03-08-2005, 04:31 PM
LSTSS02's Avatar
Originally Posted by Schantin
Schantin
2002 Camaro Z28 M6
Thank you all..........
Old 03-08-2005, 11:43 PM
fastmatt98's Avatar
Ordered one of some guy on ebay and I'm going on 3 freaking weeks and havent recieved it yet. Damn i'm about pissed. Its only 45.00 but damn I hope I didnt get ripped. Guy sells them cheap as hell so maybe a few of you got yours from him, guys screenname is masterpah.
Old 03-09-2005, 12:00 AM
TheHun's Avatar
A cooler running engine makes more power. (very old trick)
Other then that you don't cook your engine/oil it will survive more abuse.
Old 03-09-2005, 12:06 PM
ArcticZ28's Avatar
It is if you live in hotter climates... plus it's a pretty cheap mod and it definitely doesn't hurt anything... unless you live in a ridiculously cold place like Alaska.
Old 03-09-2005, 01:21 PM
01_SuperSlow's Avatar
It shouldn't give you an SES light.
You should take the stock one off and inspect it though.
Mine stock t-stat had only 41k miles, I took it off to inspect it during my last cam swap and found the rubber gasket on it all cracked up and caught inside the thermostat spring. Luckily I had a new 160 t-stat that I didn't install when I did my first cam swap.
