Nitrous feed line and wiring
Old 03-08-2005, 11:42 AM
Wile_E's Avatar
Default Nitrous feed line and wiring
Is it okay to run them together or should the nitrous feed line be kept away from wiring?
Basically, I have all of my wiring going through the grommet in the firewall and want to know if it's okay to run the nitrous feed line through there with all the wiring. I also want to run the feed line on the bottom of the door jam with some other wiring as well.
Old 03-08-2005, 03:59 PM
jd13's Avatar
I've been doing it that way for a while now, no problems here. I've got a power wire for my stereo, nitrous line, and the other nitrous wires going through there. Just check it every now and then to make sure the braided nitrous line isn't rubbing the other wires apart.
