adding stock 6.0 heads to my setup
how much should i gain going from stock 5.7 heads to the stock 6.0 heads?? its a full bolt on with a ls6 intake, f10 cam and is currently at 377hp 371tq?? Just want to know if its worth it...i got a good deal on them so I want to know if I should get them
Don't put them on if they are just stock castings. The 6.0's have a 72cc combustion chamber which will lower your compression way down into the 9's. You would probablly loose hp if anything. If they were milled, and bigger valves were installed I could see a gain, but stock for stock, you will loose.
Originally Posted by jrp
you'd have to mill .030 to get back to stock compression. assuming a stock gasket.
stock for stock there not worth the swap to me.
