my asa cam having xvalve noise
Old 03-08-2005, 10:11 PM
2KSSLS1's Avatar
Default my asa cam having xvalve noise
the asa spec is 226/236/525/525
not big at all .but i use 7.350 prods it kinda lower the noise down i was wondering if any anyone with asa cam hads the same noise
thanks
Old 03-08-2005, 10:47 PM
2KSSLS1's Avatar
tttt i need h e l p
Old 03-09-2005, 12:02 AM
dazman's Avatar
i had this cam... but i put in chromemoly pushrods at 7.4 and they worked great
mike
Old 03-09-2005, 12:15 AM
Casperws6's Avatar
i got the stock ones and no problems so far ::knocks on wood::
Old 03-09-2005, 12:42 AM
44mag's Avatar
i have this cam with manley 7.4 length pushrods. no noise.
Old 03-09-2005, 01:27 AM
2KSSLS1's Avatar
no noise at all...???????
what should be wrong ?????
Old 03-09-2005, 12:07 PM
2KSSLS1's Avatar
trtttt
Old 03-09-2005, 12:34 PM
Tranzor's Avatar
might want to check the torque on your rockers and re-torque them if necessary...
Old 03-09-2005, 12:38 PM
2KSSLS1's Avatar
i did 3 times ..
Old 03-09-2005, 01:17 PM
technical's Avatar
Bent pushrod, weak lifter, etc. Any thought as to something being broken?
Old 03-09-2005, 01:53 PM
2KSSLS1's Avatar
i know cant be the lifter they new stock ones and the p-rods are crane ..
i know Any thought as to something being broken?
Old 03-09-2005, 01:54 PM
2KSSLS1's Avatar
by the way what kind of spring you guys have ??
Old 03-09-2005, 02:22 PM
Tranzor's Avatar
I'm using Patriot Gold Duals... I get some valvetrain noise, pretty normal with an aftermarket cam. Also it's amplified by my LSX intake...
Old 03-09-2005, 02:25 PM
44mag's Avatar
comp 918s. maybe its your pushrod length?
Old 03-09-2005, 02:39 PM
technical's Avatar
Since everything is new, then maybe 7.4's are what you need.
Old 03-09-2005, 03:48 PM
2KSSLS1's Avatar
but stock are 7.4 right ..when i put 7.4 on they were loud and i went with 7.350 it kinda lower the nosie down but still there may it's setting off my knock sensor ????
