Your pre-load may not be your buddies. . .
Old 03-09-2005, 10:56 AM
Cstraub's Avatar
Default Your pre-load may not be your buddies. . .
1/4" turn, 1/2", 3/4" turn all depends on what thread size you are using to adjust with to set lifter pre-load. Don't assume since you have read or your buddy "says" that what your doing is right. Calculate the pre-load by using the thread size.
For instance:
3/8's x 24 thread. You think you need a 1/2" turn
1.00" / 1/2turn = .500" / 24 thread = .020" pre-load Not enough
Lets try 1 full turn
1.00" x 1 turn = 1.00 /24 thread = .040" Good.
Now lets try a 3/8" x 16 Coarse with a 1/2 turn
1.00" x 1/2" turn = .500 / 16 thread = .031" You are on the low side of good.
This may help it may not but I just want people aware that your 1/4" turn may be ok for your engine but for your buddy it may not be.
Chris
Old 03-09-2005, 11:05 AM
mike c.'s Avatar
all i ever did was tq-them to 22lbs and leave them. i've never checked preload,nor have i ever had a problem in years.
Old 03-09-2005, 11:44 AM
Unaffliated Racing's Avatar
What if I need .030" lash before zero preload?...lol...j/k
everyone besides chris please ignore my post.
Old 03-09-2005, 11:47 AM
PREDATOR-Z's Avatar
That is only true with non adjustable rockers
Old 03-09-2005, 11:50 AM
Cstraub's Avatar
Brian,
I would use shim stock Go grind some cams!!!!
Chris
Old 03-09-2005, 11:57 AM
Originally Posted by Cstraub
Brian,
Chris
Only if you go make some oil pans! lol and send me an ummm..."test piece" lol...one for a 92 LS-1 S-10
Old 03-09-2005, 12:02 PM
technical's Avatar
What are we running small blocks here?
Old 03-09-2005, 12:05 PM
Cstraub's Avatar
I can do that. Then Joe will just charge it to Scooter at the Charlotte race and you and I will both be in the market for jobs. We do have a couple "interesting" LS projects going on in the shop, but we are covered up with work, 6 weeks out on most pans. How about you all?
Chris
Old 03-09-2005, 12:11 PM
Call volumes have been high but that is typical for race season. I'm ready to get out to the events. I'll be in houstan on april 8-10th and sonoma CA april 22-24th.
Old 03-09-2005, 12:18 PM
z-ya's Avatar
Some are running comp pro magnums that use this method as do crane.
Old 03-09-2005, 01:10 PM
technical's Avatar
I know... just breaking *****.
Old 03-09-2005, 06:45 PM
MUSTANGEATER's Avatar
Chris
So what's the proper Lifter Pre Load on a set of Morel lifters?
Floyd.
Old 03-09-2005, 07:57 PM
LS1Tech Sponsor
Slowhawk's Avatar
That's why people like myself measure preload with dial indicators
Old 03-10-2005, 08:37 AM
Cstraub's Avatar
Originally Posted by MUSTANGEATER
Chris
Floyd.
Rick, the engineer at Morel, says you want at least .030".
Chris
Old 03-10-2005, 09:18 AM
DAPSUPRSLO's Avatar
We need a sticky for this thread. Excellent info and something the general crowd needs to know. Like said before it is consistant on stock rockers but aftermarket adjustables will not be constant.
