Identifying an LS1
Identifying an LS1
I am considering buying a pull out motor complete with acc, PCM, and harness. To keep it "honset", I'd like to know how to best verify the model year by looking at the motor and/or it's code. I found this thread https://ls1tech.com/forums/showthrea...fying+year+ls1 in my search, but the info only goes up to year 2000 (Z). I would appreciate info on the codes for 2001 and up. If there's another thread that covers this, then please direct me to it. A pic of where the code is located would be helpful too.
Thanks,
Andy1
Thanks,
Andy1
Originally Posted by 8KickassRS9
what year car is it out of?
Guys, if I can't use the head casting number as gospel, then I'd really like to be able to read the code.
Thanks,
Andy1
Originally Posted by jrp
can you get all the codes and then come back and tell us. we can better help you that.
Thanks,
Andy1
Originally Posted by Andy1
Since I will be buying from a salvage dealer, I may not be able to see or verify which car it actually comes from; ergo my need for reading the code.
Thanks,
Andy1
Thanks,
Andy1
SN95 Director
I appreciate the offer, but I'd like to be able to identify the motor on the spot. Actually, all I really need are the codes for the year of the motor, as I think the other stuff is either un-necessary, or can be identified visually....can't mistake it for a LQ4 or an LS6.
Thanks,
Andy1
Thanks,
Andy1
well it'd be easier if GM only used one set of pt# per year but they use multiple part numbers for the same parts often superceeding (sp) others. thats why i say it'd be easier to get the numbers first so we could help you out.
"The tenth [character] is model year v= 97 w=98 x=99 z= 2000 I don't know what they did after that"
So I assume there is nothing similar in the 2001 and later part numbers stamped on the block?
Andy1
