Cam questions...
Old 03-10-2005, 12:40 AM
Hot02SS's Avatar
Default Cam questions...
I was looking around at a few cams and relly like the T-Rex cam from Trunder Racing. Which cam do you think I should get? http://www.thunderracing.com/catalog...2&sid=88#P2466
The only other mods I want to do are LT headers.
Old 03-10-2005, 12:47 AM
Boostaholic's Avatar
What stall and gears are you running? I am a ex-TREX owner, and would not recomend it without flycut pistons, 4.10 gears and or a big stall, its pretty cool to drive around though, I loved it but then again I'm wierd (Drove car around open headers most of the time, with TREX loping away)
Old 03-10-2005, 12:59 AM
Hot02SS's Avatar
Im on stock 3.23 gears with no stall. That is exactly what I want, a cam that is fun to drive around on the street with. I dont plan on running the 1/4 very much so a stall isnt that important to me.
Old 03-10-2005, 01:25 AM
chaos's Avatar
I don't think the T-Rex would be too fun driving around on the street unless you tune the shiznit outta it . Would be pretty fun turning everyone's head with the huge lopes though
Old 03-10-2005, 10:32 AM
luv2spd's Avatar
You'll be very disappointed in the trex imo. With stock gears and stall it will be a dog down low, not to mention the driveability issues you'll have. It would sound good though.
Old 03-10-2005, 10:53 AM
jrp
SN95 Director
jrp's Avatar
well then you dont want the Trex
SPECS
Thunder Racing TRx V.2 - 242/248 .608/.612 110lsa +2
Piston to Valve clearance
When going with a cam of this size, piston to valve clearance becomes more of a concern. Both of these cams are well within the spec of allowable clearance with stock heads and stock shortblock. They are, however, on the tight side of the spec, but definitely something that can be used with the proper attention being paid to the install (intake centerline) and valvetrain selection.
The cams have the following PtV with a stock cylinder head (stock valves, stock valvejob, no milling), '98/'99 GM graphite gasket (.053", compressed), stock shortblock (pistons .007" above deck), and a 108* intake centerline:
V.2: Intake .070", Exhaust .090"
For those that feel that this is too tight and are uncomfortable with this clearance, we do offer the ISKY flycutting tool which will make valve reliefs in your stock pistons. The heads do need to be removed to perform this task, so be prepared to purchase new gaskets and bolts. You can notch the pistons with the motor still in the car. You can also just select a smaller camshaft and not have to worry about any of this.
The pistons in my car are not notched and I have had no problems with any PtV.
Valvetrain
We recommend either the Comp 921s or Crane 144832 dual springs due to the aggressive nature of this cam. Thunder Racing 7.400" hardended pushrods are needed as well.
Tuning and Driveability
Tuning is going to be an absolute must with either of these cams to get the idle and driveability sorted out. Once the tuning is taken care of, for a cam of this size, it drives pretty well. Still, this cam is not for the faint of heart. It was designed for those looking for a cam that makes very impressive power with stock heads. It can be used in a daily driver if you don't mind the driving characteristics of a large cam. For those looking to drive this cam everyday, I would recommend a complete tuning session, gears (4:10s or steeper in a M6), and a loose converter in an A4 car.
From my limited street time with the V.2, it really is quite driveable. I just put 25 miles on the car in the last hour with the Hooker catback installed and it is much better now with some additional tuning Geoff did.
We will be spending a full day early next week taking care of the final driveability tuning. It is 10x better than what it was with the stock tuning.
Rest assured, this only the beginning of the new camshafts Thunder Racing will be offering. The V.3 is already in the works.
If anyone has any specific questions regarding this cam, post here or sent me an email (jason99ta@hotmail.com). I'll be more than happy to help you as best as possible.
Jason
Old 03-10-2005, 11:36 AM
nspr8td lt1's Avatar
the t-rex is not for you.
Old 03-10-2005, 01:02 PM
Hot02SS's Avatar
What cam would you guys recomend? I want a cam that is good on a daily driver, and offers a good power gain without going extreme on the gearing of the car. Also I want a cam that gives good power down low as well.
Old 03-10-2005, 01:07 PM
jrp
SN95 Director
jrp's Avatar
tr224 112, tsp225 112, ,fm13 112, ect.
but i'd get a TC before the cam anyway, theres nothing worse with an a4 then a mismatched combo. i've ridden in a few and they feel slow as ****.
Old 03-10-2005, 01:09 PM
Keenov's Avatar
Have you considered the TR224 on 112 LSA ?
Old 03-11-2005, 01:41 AM
chaos's Avatar
Are you planning on having the car tuned the same day you have the cam installed? If so, the cam in my sig is pretty good. It's a little more rough on your valvetrain, but it made pretty good power on the dyno. Or the TR224 on a 112 lsa is a pretty nice cam also. Very popular.
Old 03-11-2005, 01:59 PM
Hot02SS's Avatar
Yea, I wanna get it tuned on the same day. The closest dyno tune to me is in Memphis (about an hour away) so I will have to drive down there to get it installed.
Old 03-11-2005, 03:06 PM
O2bqwik's Avatar
no place in memphis installs cams and no place in memphis does tuning. Closest place for both is in Little Rock. Your wasting your time getting a cam without a conveter the cam isnt going to be able to get into its power band very quickly with the stock converter. I recommend installing the cam yourself, and driving to Little rock and getting the tune. With the auto id say go with the tr224 or a comp 224/228 or something along that line. If you need anything just let me know.
Old 03-11-2005, 04:14 PM
thebernsZ28's Avatar
Get A TC
Then some GEARS
Then a CAM
