nitrous trouble help...
Alright guy's I need some help. I'm running a dry 100 shot, From N.O.S. on my otherwise stock 99SS. I have a window switch set at 3000rpm. when the nitrous kicks in at 3000rpm, It does not feel like I'm getting the full affect. Its inconsistant power. I get power veriation through out the pull. I also found that when I purge, It's inconsistant. If I hold the purge for a couple of seconds I get air,then nitrous,then air,then nitrous,then air, and so on.
Can someone point me in the right direction, as where to start looking. Thanx.
Restricted User
Hmm.
Dirty filter, if you even have one?
Improper bottle angle, siphon tube not in lowest edge of bottle?
Valve not fully open?
Bad electrical connection to the relay/solenoid/WOT or WS?
Low bottle pressure?
That about all I can think of. Good luck
Charlie
Charlie
Originally Posted by Z284U2TRY
are you running a fps switch? How long are you purging?
Originally Posted by TRYTHSS
if you think that it is bad fill, is this the first bottle that this has happened with? if not how long has this been a problem???
they might not be filling it right.
bad fill or bad bottle (leaking at the valve) which is almost un-noticable. Also a bad fill could go hand in hand with a bad bottle. On other thing, you may also have a leak at the purge point, check all connections with the lines to bottle.
Just so yall know I dont think that it would necessarly be a bad fill.. Its not like your going to get some nitrous that just dosent run as good.. If you want to make sure you are getting your moneys worth outta the fill then the next time your bottles empty, go weigh it and when you get it filled weigh it again and if it was filled correctly then it will be 10 pounds heavier.. And most bottles have the unfilled weight on the lable unless it has just worn off.. I would be more concerned about your bottle position than a bad fill.. That is the most common mistake when mounting a bottle..
Originally Posted by cruedas
Yeah, I'm running a fps. I purge until I get a good nitrous flow out the nozzle.
Well the fps shouldent be affecting the purge, but you definately dont want to ground the nitrous sol through the saftey switch.. Use the fps to break the ground on the relay..
I had a purge noid sticking open and i noticed cause it wasn't hitting like normal.
