Slp Lid Install
Old 03-10-2005, 01:57 PM
FH212's Avatar
Default Slp Lid Install
Hey guys, Im new here so you dont hate me for the dumb questions.I'm going to install my new SLP air lid w/K&N filter @ short throw shifter in my firehawk sat.Just wondering if there was something i should watch out for before i do it. Thanks
Old 03-10-2005, 02:05 PM
Possible Scammer - Buyer Beware - Issues Unresolved
00ls1's Avatar
easy installs, have fun
Old 03-10-2005, 02:09 PM
black01_WS6's Avatar
the harderst parts that i came across was getting the oxygen sensor out and put into the new piece, have someone with strong fingers. other than that you don't even need the directions, and shouldn't take too long. might want to use some locktight when putting in the shifter. have fun you will see a impovement right away.
Old 03-10-2005, 08:44 PM
sawedoff's Avatar
Here's the part numbers in case the situation gets the better of you and you break something. Or you can be smart and leave them in the OEM lid and just get new ones for the SLP unit.
Intake Air Temp Sensor (IAT) #12160244 --sensor assembly
IAT Grommet #24504388 --grommet
Old 03-10-2005, 08:59 PM
FH212's Avatar
Thanks for the numbers and advice.
Old 03-10-2005, 10:06 PM
67SS&99SS's Avatar
When you put your slp lid on make sure the front tab is in the groove. Many people forget to check this the first time and the clips that hold the lid down will not stay fastened. Here is a pic.
Old 03-10-2005, 10:42 PM
FH212's Avatar
Thanks for the pic Andy,That will help.
Old 03-10-2005, 11:22 PM
99Hawk262's Avatar
You might want to get some gasket material and cut a gasket for the shifter. When I installed my Pro 5.0 in my old SS, it wanted to chatter. A homemade gasket solved it right away. Also, you might want to try the Fernco Smooth Bellows while you are working on the lid. It's a six dollar mod and it looks pretty sweet too. I'm sure there is performance gains, but nothing you'll feel. But hey, any bit helps. Just buy the 3"X3" Fernco rubber fitting at Home Depot. Look at the top of the External Engine page to the exhaust guide sticky. Read through that and find the smooth bellows area. There's great info there for how to do it. It was a bit tricky to get it all together right, but there is an awesome growling sound from the engine now at WOT. Have fun and let us know how it went.
Old 03-11-2005, 08:26 AM
FH212's Avatar
I bought a SLP smooth bellows so hopfully that will work.Did you put the gasket inbetween the shifter and the body?
