Why is the LS1 slow to rev down?
Old 02-28-2003, 02:36 AM
Midnight F-117A's Avatar
Default Why is the LS1 slow to rev down?
When I rev the LS1 engine, it revs fast but why does it take a while for it to rev down?
<small>[ February 28, 2003, 02:38 AM: Message edited by: Midnight F-117A ]</small>
Old 02-28-2003, 04:26 AM
Patman's Avatar
Default Re: Why is the LS1 slow to rev down?
I believe GM programmed it this way for emissions reasoning.
Old 02-28-2003, 11:30 AM
dug
dug's Avatar
Yep, I hate it too. It makes it hard to shift quickly and smoothly. Is there anyway to delete it?
Old 02-28-2003, 08:02 PM
DóòD's Avatar
Ya! I noticed that on the 02..
The 98 doesnt seem to have this 'problem'....
Old 02-28-2003, 08:27 PM
BMW ///M Nerd
BAD ASS TA WS6's Avatar
There is a motor used on the throttle cable which brings the rpms down slowly, so the LS1 does not stall after the rpms drop quickly.
Old 03-01-2003, 12:26 AM
Can LS1 Edit fix that or a custom PCM reprogramming?
<small>[ February 28, 2003, 12:28 PM: Message edited by: Midnight F-117A ]</small>
Old 03-01-2003, 05:18 PM
Administrator
unit213's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by BAD *** TA WS6:
<strong> There is a motor used on the throttle cable which brings the rpms down slowly, so the LS1 does not stall after the rpms drop quickly. </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif"><img border="0" title="" alt="[Confused]" src="images/icons/confused.gif" />
Where is this throttle motor you speak of?
Old 03-01-2003, 05:44 PM
<strong> There is a motor used on the throttle cable which brings the rpms down slowly, so the LS1 does not stall after the rpms drop quickly. </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">What motor? There's only a cruise control motor on the throttle cable. If you took that off and watch it while revving the engine it does not do anything at all. Even revving it manually by roating the throttle blade bellcrank, it still does it. I believe it has to do with the injectors and the PCM controlling it.
Old 03-01-2003, 10:59 PM
3GROC's Avatar
when mine is cold or colder it doesnt do this which leads to choppy shifting kinda
when hot it stays up there which I think makes it easier to shift faster and smoother when power shifting
I have a 2000
Old 03-01-2003, 11:09 PM
Well duh mine is a A4, not a M6...
Quick Reply: Why is the LS1 slow to rev down?
