Block Prep
Old 03-11-2005, 05:18 PM
Racer8102's Avatar
Default Block Prep
Is it just me or does it take a long time to clean the block and head bolt holes before installing new heads. I spent probably an hour cleaning each side of the block (removing old gasket) and another hour each side cleaning the bolt holes out, Im glad I cleaned them out, sure were full of crap! Thats all.
Old 03-11-2005, 05:25 PM
CharlieLed's Avatar
It takes a lot less time if you have it tanked. Always good practice to chase the head bolt holes to be sure they're clean, the thread dope on the stock bolts really gums up the threads. Don't use a regular tap on them though, you will cut away some of the metal and weaken the block...
Old 03-11-2005, 09:32 PM
ZO6 LandRocket's Avatar
What kind of tap would you use then?
Old 03-11-2005, 09:52 PM
CharlieLed's Avatar
The "tap" is really a thread chaser or thread "roller". Instead of having sharp cutting edges like a conventional tap, it has smoother edges that gently pushes (or rolls) the aluminum threads into shape. These tools are part of the TimeSert kits and the Kent-Moore thread kits (made by TimeSert for K-M). You may also be able to find them from other tool manufacturers...you'll need an M11 x 2.0 size for the head bolts.
Old 03-11-2005, 10:25 PM
HAMRHEAD's Avatar
Yes it does take awhile but is well worth it!
Old 03-13-2005, 11:45 AM
Thanks
Old 03-13-2005, 11:49 AM
GueSS Who's Avatar
Really all you need to do is take a old head bolt (short one and long one) and cut a groove on each side of each one that kinda goes in a S shape up the bolt threads. Then run it in with a impact about 2 or 3 times. After that there is nothing left in the groove of the bolt that you cut out. Works really nicely and it is cheaper.
