Both Pulleys or Just one??
Old 03-12-2005, 02:55 PM
Y2K SS's Avatar
Default Both Pulleys or Just one??
Hey I wanna get the ASP pulley but I'm not sure if I should get both the crank and alternator or just the crank. Any suggestions???
Old 03-12-2005, 02:58 PM
txhorns281's Avatar
If you're not running a stereo or too many accessories, you'll be fine pulley only
Old 03-12-2005, 08:30 PM
SS SLP2's Avatar
a4 running crank only last 5 years no problem, idleing at 676-700 charging show little low but no problem
Old 03-12-2005, 09:39 PM
ULTIMATEORANGESS's Avatar
same here.
Old 03-12-2005, 09:46 PM
98boxer's Avatar
What gains in performance? Smog legal?
Old 03-12-2005, 10:29 PM
99trickin's Avatar
ive got a decent stereo system so i have been using both for a couple months now with no problems.i did not feel any difference in performance but i probaby did gain some.100% smog legal.
Old 03-12-2005, 10:49 PM
txhorns281's Avatar
Not sure if there's any true "power" gain but you take away rotating mass and slow your accessory pullies in relation to crank rotation. All in all it should be good for a tenth in the 1/4 due to quicker acceleration!
Old 03-15-2005, 11:09 PM
Y2K SS's Avatar
Cool.... so just the crank pulley is fine then?
Old 03-16-2005, 03:26 AM
ZR2877's Avatar
I went with just the crank pulley and haven't had any problems.
Old 03-16-2005, 03:37 AM
Martingale's Avatar
You guys using the stock belt with the underdrive crank pulley?
Old 03-16-2005, 03:58 AM
TNormZ28's Avatar
Uh, no. Smaller pulley = smaller belt. When you get the pulley the instructions will tell you what to get. And for an M6 car just the crank pulley will suffice. Some A4's need the overdrive alt pulley for charging the system.
Old 03-16-2005, 10:24 AM
12secSS's Avatar
Typically the manual cars can just use the crank pulley. Some autos can get away with just the crank pulley (I have this setup on both cars), while other autos may need the over drive alt. pulley. I will probably be purchasing the over drive alt. pulley for our Camaro SS for safe's sake.
Old 03-16-2005, 02:33 PM
Kirby's Avatar
Who would you suggest I go through to get the crank and alt pulleys?
Old 03-16-2005, 02:42 PM
Shuck's Avatar
I agree, the alt pulley is not really needed. I have two amps right now one is 420 watts RMS and the other is 500 watts RMS and I didn't need the pulley.
Old 03-16-2005, 10:17 PM
Y2K SS's Avatar
There's a group purchase going on right now thats why I was asking. Go check it out.
Old 03-17-2005, 09:54 AM
Kirby's Avatar
Where is this group purchase? If it is a thread, please post the link. I want to take a look at the price before I do anything.
